new sprocket question
xxmiaja
xxmiaja
atlanta
so some how my key tryed to spin around in the keyway on my axle and broke the hub where the set screw goes in. i want to order a new sprocket but the ones i see do not have a center to it to tighten down on the axle.i also saw some axle hubs that bolt to the sprocket but they have no set screw what should i order i need the set screw to keep sprocket from sliding side to side
That sprocket should never have been anywhere near a go kart, it wasn't designed for high speed or high torque applications...
What you need is something like this & a sprocket to match it...
xxmiaja
xxmiaja
atlanta
Are you serious...that sprocket came on the go kart but the engine was a small 6.5 HP my engine now is a predator 420 cc 13 HP engine so I need a stronger hub?
Thanks, you just made my point for me...
Yes, you need a stronger hub; you doubled the torque load so, you need to double the strength of the sprocket hub...
xxmiaja
xxmiaja
atlanta
OK got it..I really appreciate your help I will start looks ng for something stronger now
