... ok let me solve this problem right here n now... before you go spending $ that youll probably end up re-hashing out the issue later on the 'newer' one...
I had the same problem... heres what I found...
The test: Just gonna need the driver inner clam shell the side the belt rides on w/ the weights on/in it... and copper ring removed off the TC...
Take the copper bushing ring... now slide it into the clam shell opening(reenact as if the clam shell/clutch was engaged). You will more than likely notice that the ring will become stuck 'partially', and slightly jammed to pull out freely... what is happening is the springs and everything are working fine, and more than likely you did nothing wrong... but for some reason(grooves usually), that ring seems to become jammed in the clam shell, as you decelerate, keeping the belt/clutch engaged, dragging the motor down to a stop. You tapping the driver, dislodges the ring from the clam shell, freeing it to release belt tension... thus not killing your motor upon slowing down.
The fix....(what I did)...
First I took the clam shell and put it on the lathe(just need something to turn it steadily... afixing it to a drill that is clamped to a table, would work aswell... dont need to be fast... just steady for an even removal of barbs/gouges). As the lathe turned the shell, I took 150grit sand paper to the inside of the opening(where the copper ring slides into). After removing ALL darkened coloration/95% grooves/gouges(sanded to bare metal), I polished it w/ 800 grit. I checked the clearance/slide of the ring again... alil better, but still sticky. I took the ring and put that on the lathe. I noticed that if a slight bevel was put on the rings surface, it would clear and slide, free and clear of any jamming, inside the clam shell. First 150 then polish w/ 800... the entire outer surface. Then on the inside I sharpied an arrow indicating the beveled side.
Short version...
A. Sand evenly, to bare metal, the inner hub part of the inner clam shell(any grooves should be sanded to a smoothed minimum)... polish off.
B. Sand at a slightly beveled angle, the outer face of the copper ring... polish, so as to slide freely, in and out, of the clam shell's orifice.
