New San Diego Transplant living in Spokane WA
perceptionist
Spokane, WA
Hey all,
I recently moved here to Spokane and landed a nice house with a workshop. I have been getting all the toys I never had the space to work on in San Diego.
My most recent purchase on Friday 7-11-08 happens to be what led me to these forums.
It is a homemade go kart with a 600cc motorcycle engine from a Kawasaki GPZ Ninja.
I have always wanted to build one of these. The engine runs fine but could use some TLC. I cleaned the carbs last night and now it idles without help. The guy I bought it from had it for 4 months and never changed the oil or filter, and never had a fuel filter on it which would explain all the junk in the carbs. I still need to synchronize them.
I am happy with the engine. I think I might be able to do better on the frame once I get myself a welder and learn to weld. I am undecided on wether I want to build a whole new frame around the engine or use the existing design and attempt some upgrades.
The only reason I can't drive it at the moment is the weld that held the brake caliper on the frame broke loose and the brake pads were lost. The caliper is not from the motorcycle the engine was from, so I don't know which pads to buy. I do have a neighbor who offered his old motorcycle to salvage parts from, it has good calipers and discs front & rear.
I am unhappy with the design of the rear axle. It does not seem to be designed for swapping out parts (sprocket, brake disc, U-joints etc...) as everything is welded together. I would like to look into some sort of axle kit or try my hand at fabricating one.
The suspension and steering in front also could use a face lift. (rack & pinion from a fiero?) :wai:
I have looked into the pros and cons of live axles and single wheel drive. I would like to design or find a 2 piece live axle that has two steel plates that meet and can be easily bolted or locked together when on the dirt or sand for power to both wheels and then I can disengage for driving on hard ground to facilitate easier turning.
I am exploding with ideas on what I would like to do to this thing. I will definitely be frequenting these boards to pick some brains in my journey.
