new project! hehehe
freakboy
the names 'mater
hick town
I freaking wish but close i belive were switchin the title over tonight. its a 1978 f-150 ranger. not 2 wheel drive =( and it has a inline 6 300 ci. Its all in good shape just needs some lovin ahahah and some paint and a new clutch.
anderkart
Surprise Arizona USA
Congrats, those were good ol engines. Be sure to pop a new brass freeze plug in the rear of that engine while you got-er apart doing the clutch. It'd be a bummer to have to tear it all back down again later for a couple dollar part...
freakboy
the names 'mater
hick town
Yeah I think im going to try and find a dana axle for the front end and a dana transfer case so its 4x4 ima need alot more then that tho.
newrider3
Colorado
Woo 300-6. Got the same engine in my '82. Has some balls compared to modern small truck engines, and more torque than a 302 from the same time period IIRC. What trans do you have?
freakboy
the names 'mater
hick town
Lol little late suburban hahah we already established what it is ahahha.
And im not sure yet i didnt take that good of a look at the trans from underneath i looked more at the frame and just a quick look over at stuff. Im sure its either a c4 or c6. I havent figured out howmany gears or anything like that but when i get it home tomorrow ill figure it out.
freakboy
the names 'mater
hick town
Well i picked it up lastnight at 9 at night in the pouring down rain....that was fun used two come alongs to get it on the trailer and to get it off we pushed it off and threw a log behind the rear wheel to stop it. I will have pictures when i get home tonight and i have the battery on the charger and im going to see if that little 6 will start.
1992suburban
I wanna go FAST!!
Sanford, NC
that 300 is a good motor tuff as nails.
the carbs SUCK!! though buy a new one at sadvance auto for 80-90 bux.. off a mid 70's truck.
if it gets gas and spark it will run..
freakboy
the names 'mater
hick town
yeah the batery is on the charger and i found the funnyst thing ever the one rad suport on the drivers side is a **** sign lol i cant read much.
newrider3
Colorado
Pour some ATF down the carb before you crank it. When the truck has sit for a while there won't be any lubrication left on the cylinder walls, and the ATF will give it some top end lube when you crank it.
freakboy
the names 'mater
hick town
I got her to crank over all the electrical works except the radio and the rear right turn signal. I found out why its not running the fuel pump is dead so i went to autozone ordered one cause they didnt have it in stock so i should be able to pick it up tomorrow morning. I cleaned all the windows and small stuff like that. tomorrow im going to put the new fuel pump in and compression check each cylinder. I did get it to fire over by dumping fuel in the carburetor.
freakboy
the names 'mater
hick town
175,000 miles on the engine and i figured out its not the origional radiator. lol the origonal is bigger then the on in there now thats why the farmer i got it from used a no smoking sign to hold the radiator on ahaha.
