new predator 212 problems
tundrabeagle3
Ca
i got a new predator 212 and i put it on my big mini bike and i have been having problems with the motor accelerating. i opened my motor at first to check if the cam and crank dot were lined up. they were not and i lined them up. what do you guys think?
If it is new you should not be having any problems. Take it back.
tundrabeagle3
Ca
I tried taking it back today to exchange it, but to my luck they were out predator 212s. so i have to fix my predator . i checked the timing marks again and took a pic. Im beginning to think my cam and crank dot are not correctly marked.
Blazkowiez
Kart Aficionado
Houston, Texas
Do you live in an area that only has one store? My city has 5... I wouldn't spend your time on this. Wait for a return bro.
tundrabeagle3
Ca
the nearest hf is in another city and they said they were not going to get any in a while.
tundrabeagle3
Ca
i opened the valve cover and i reset the valve lash. It seemed to be way off, i set it to.003 exhaust and .002 intake hopefully when i try it tomorrow it will work.i will post what happens tomorow.
r_chez_08
Should be in the shop...
Cornwall, UK
Leave no evidence behind...
I heard they get a company to disassemble them and check why they broke.
I doubt it. I really, really doubt it. For what these things cost to manufacture, and for what they sell them for, I can't see it.
Personally, I am a believer in the warranty concept. You paid for a new, properly functioning engine, you should get one. I don't know what Harbor Fright's customer service policy is like, but if it were Princess Auto, they would have one shipped from elsewhere to exchange yours. Either way, if you cannot walk out of the store with a new engine, then you should either get a refund, a rain check, or a price adjustment towards another engine. That said-
Folks need to understand what's right and wrong when it comes to warranty returns. If you have purchased an item that it coverned under warranty and it's not right, bring it back. Don't start ripping it apart to find out why. This is called tampering, and in every warranty it clearly states that tampering voids the warranty. All you need is the wrong person to look at it and figure out that you messed with it, and you're out of luck- stuck with an engine that doesn't work with no recourse. These stores know where the products come from, they know what they're all about. They expect warranty returns, and accept it as part of the cost of doing business. If it doesn't work, drain the fluids, pack it up, and bring it back.
tundrabeagle3
Ca
Am curious as to what led you to believe that this was the problem.
Sounds very suspicious!!!
I have read that these motors sometimes come with the timing dots not lined up. i did try to see if they would ship me a motor or give me another bigger motor but they said they could not do it. i am going to try to get it going myself if i have no luck then i will return it. the engine is completely stock and un modified. it is still in new condition.
...apart from the one broken gasket seal. Stop, pack it up & take it back. The worst you'll get is a refund.
The warranty policy over there must be really slack. If this happened here they'd either have to find a replacement from another store or give you a refund
tundrabeagle3
Ca
i gave it another try and had no luck . i am going to return it for my money back and keep an eye out for a used honda.
