New noram ge clutch problem.
tmm21
A buddy of mine just purchased a new noram ge clutch for his predator 212 go kart. The problem we are having is the clutch will just randomly engage at idle and make a high pitched grinding noise. It'll even engage by just pushing the kart with the engine off. Sometimes he can manage to drive it for 50-60 feet before it start making the noise and bogging the engine. It has heavy shoes if that helps.
tinamcjittles
ello m8
Allovau
Have you taken it apart to check it out? It doesnt make sense to engage when you push it since the bell is supposed to freespin... and what is your gearing??
tmm21
12 tooth driver 62 tooth driven #35 chain. I don't think it's a gearing problem. It's fine for the 50-60 feet it's actually operating rights. As far as we got was taking the chain off. it'll will free spin by hand but as soon as there is any load it binds up. I was thinking his chain may be too tight but we its just as loose as mine.
tmm21
Should it be inboard or outboard? Everything I can find shows both.
Kelly Wood
The Mad Kartist
Salt Lake City Utard
It can run either, but the shoes must be in the proper position.
In the pic below, if yours runs inboard and is using the TOP left setting with heavy shoes and light springs, it will be one choppy noisy thing.
The pic below shows what I run on mine. I use light shoes and the white springs.
Show us a pic!
