Tpdingo
Same with mine. You can clean a comet to nearly brand new if you have a little bit of patience and basic cleaning supplies. Helps if you have a second small engine with a 5/8" shaft for cleaning the driven pulley. That's what I did, with a Predator 79. WD40, Brake clean, brass brush and steel wool was plenty. Don't recommend using steel wool though, nearly killed me, twice.
Also make sure to have 3in1 oil to line the moving parts and spray Dry Lube for the inside of the T/C though oil will work in a pinch if you don't plan on sand or offroading.
