t1704
seems to be too big of a distance...
(that 5959 belt is for ~7" of distance between the two.)
BUT the jackshaft plate the driven unit is mounted to should be adjustable (IIRC up to .5" at least) so chances are PO moved it out since he accidentally bought the next bigger belt *shrugs*
check if you can move the jackshaft plate closer to the engine (keep in mind that JS plate is fixed to the engine with the engine bolts or (if still stock) with a set of studs [nuts on both ends]
Hey guys, I happened to find this belt which suggests it's for a 6" driven with a 7 3/8 center to center spacing.
belt
Would it not be better to use this (instead of 5959) rather than try to adjust my jackshaft, then have to potentially shorten my chain? Let me know if there's something I'm missing here and as always thanks for the help as I'm still learning these machines.
