New Member needs direction
checks618
Norristown PA
Hello everybody,
I just bought a Manco Dingo 388-05. It has a Briggs 190432 8hp Engine. Cart is in decent shape. Guy said it ran last year (they always do). I put a new carb on it, but cant get it to turn over. it has spark. I guess what I need help with first is where to go for parts. It needs a new petcock and fuel line. Is there a fuel filter? Where can i find a manual? and if i get mad enough, what is the biggest simple swap motor i can go with?
Fix that briggs.
The carb probably needs a good cleaning. No fuel filter unless you see one in line between tank and carb. It would be an obvious add on.
Dingos are a blast!
Post some pics. We like to see your toys.
---------- Post added at 08:26 AM ---------- Previous post was at 08:24 AM ----------
Missed the part where you said new carb.
Sometimes the petcock can get clogged I've heard.
---------- Post added at 08:29 AM ---------- Previous post was at 08:26 AM ----------
Are you getting compression? Take the sparkplug out and put your finger in the hole and pull the rope. It should blow your finger off the hole with some pressure. If not a valve might be stuck.
Are you positive it makes spark?
Is the kill switch in the run position?
Unhook the oil sensor.
Many possibilities.
Bbqjoe
Banned
Location, Location
Hello everybody,
What's your firing order?
checks618
Norristown PA
She lives
I got it running. Replaced the sparkplug and kill switch wiring. I'm struggling with dialing in the carb. Can't get a good idle, or a smooth ride. What does each screw do (3)? Do you have to leave a little choke on?
---------- Post added at 06:20 PM ---------- Previous post was at 06:17 PM ----------
It's a Briggs model 190432 type 6035 01
Staff Murderator
That's easy! It's 1, 1, 1, 1, 1, 1, 1, 1.
Image unrelated.
