007SwagBaus
- Messages
- 11
- Reaction score
- 2
Hello all... so im building a mini bike. just something out of 3/4 12ga box tube...I have a motor out of a toro snow blower. its an R Tek 2 stroke 141 cc 5hp.
the manual says the engine is governed at 3800 rpm by "air vane"
does this mean there is no internal one in the motor and its limiter is the fixed carb? if i get a cheapo carb that i can throttle i'll be good? i see like chinese type ones for techumsa for like 15 dollars. the two bolt mounting looks to be the right size.
and then i found a gearing calculator what should i put in for the engine RPM? can this little sucker go faster than 3800 safely?
also im gonna go the jack shaft route. does anyone have any suggestions on what gears i could use?
this is mainly gonna be parking lot/ gravel. use so id like top speed. maybe 30 to 35 mph
to diygk....
