New kart alot of Pictures inside
Whiteghost06
Ok so went and look at the cart and look and ran great so i pick it up but i still cant figure out what brand/engine it is so if any one knows or knows were i can go to find out that would be great also if you can recognize any parts please let me know im new to karting so any help would be great thank you in advance :cheers2:
kendelrk
redneck engineer
westland michigan
looks margay, with a briggs flathead. take a pic of the very front of the block, right next to the shroud. It may be a raptor
kendelrk
redneck engineer
westland michigan
go down a little further in the picture. i need from the bottom of the crankcase up. like from the bottom of the shroud up
Whiteghost06
any better the guy i bouht it from said it was a 5 hours brigs but it was not stock
kendelrk
redneck engineer
westland michigan
you have a 5hp briggs raptor, this is i beleive a margay frame, my neighbor had the same. Thesse were apparently for kt100 racing but my neighbor had the same engine on his. beware that engine is a powerhouse and it can do some crazy things. by not stock you can see theres a filter and header. he probablly removed the governor and did some inside work
bighead
Pacific Northwest USA
Thats sweet kart man. What did you pay for it? It looks well taken care of or and or recent restore. Nice job...
Wait for Andekart to chime in.
Whiteghost06
yeah thats why i jump on it the guy said he had another cart and did no use this one anymore btw what kind of oil would one put in here would like to change it because i do not know how old it is
bighead
Better wait till the engine guy chime in about the oil.
Can you make a vid of it running?
I find karts like this with no engine a needing lots of work for $300. Your needs nothing and came with a raptor? You shopped well friend.
I would guess the real value is what make and model your frame is.
Whiteghost06
You did not buy that. YOU STOLE IT BIGTIME. IMO
Take care of man. Don't trash it. And keep your friends off it.
See of you can race in a vintage class? Or a class that fits your kart.
yeah deff taking good care of it and deff no free rides lol as this is my new found hobby
Whiteghost06
its a briggs 5hp. in all my engine i use 10w-30 its great for winter and summer
does it mater what brand synthetic or non synthetic also how would i messure it because the engine is at a angle and how can I figure out what brand and.model the.frame is there's.no markings on it thanx for the help guys
anderkart
Surprise Arizona USA
I'd suggest you start by asking the seller what brand/weight of oil is in your engine now. Some of the specialty kart racing oils brands have additives that dont mix well with other brands. Even after you drain the old oil, some of the residue will remain and this can sometimes cause problems when switching to other brands.
If he'd just previously used oil made for cars, (synthetic or petroleum based) there probably wouldnt be any problem switching to most any other brand of automotive oil. But if he used one of the special kart racing brands, you'd want to either stay with that same brand, or flush your engine out with mineral spirits before changing to another brand.
Guys that race engines like yours (w/15-degree motormounts) typically used 14 ounces of oil. You'll just need to use a measuring cup to get the right amount. (You could use 16-ounces if you want, but it'll probably puke those extra 2 ounces out your breather at high rpm)
I use/recommend strait 30 weight Redline brand, synthetic racing oil in my racekart engine. I buy it from a local automotive speed shop, but you could find it online too.
Are you running gasoline or Methanol in your engine?
_______________
I've been trying to help you figure out what brand your kart is, I've posted your pics on a kart racers forum. We're still not sure what it is, but you can check out the thread here: http://karting.4cycle.com/showthread.php?p=4125280#post4125280
