New Honda gx270 coils
mark123
Prince Edward Island, Canada
The old engines would run as long as the single wire wasn't grounded. These new ones will not run with these wire not connected to anything. I ended up splicing 2 of them together and that leads to a grounding switch. The third wire us yellow and leads to low oil shut down. Any harm in running it this way. It will not run unless those 2 are twisted together. I am not using the factory key switch box. Also I removed the charging coil as I do not need it.
