New here .... need steering help on a Murray Gokart
hankll
NASHVILLE AREA -TN
I work on Riding lawn mowers and other lawn equipment, so mechanically, I'm inclined to work on this, but the steering is messed up. As I just bought this for my Grandson, I just wanted a good safe go kart for him to have fun with the rest of the summer.
I posted the main problem about it in the Kart discussions forum....it explains a lot of what I'm dealing with.
I know of a motor cycle and go kart shop in Nashville, that has a large junk yard. I may be able to find some parts. I need to get the seat belts replaced, for sure.
brandongeiger2
Valrico Florida
Most likely your tie rods need to be adjusted its pretty simple but painstaking...
What you need to do is turn the steering wheel to its center
Look at the wheels if they are turned out you need to unbolt the tie rods and lengthen them by un screwing the eye end out a little on both sides
If their turned in you screw the rod eye in now this only works if the bracket that connects the spindle to the tie rod is behind the front axle(or points backward) which should be the case with your kart....
If the bracket faces forward(or is in front of the axle) the tie rods need to be tightened to be brought in and loosened to be brought out.
A very important note:
Make sure the second nut is secured on the tie rod once you size them correctly if not all that hard work will go to waste.
I hope you get the kart working for your grandson...Good luck!
Brandon
Blazkowiez
Kart Aficionado
Houston, Texas
Is your Murray using a gear to lead to the tie rods rather than just a steering rod leading to the rods? I know that statement was super vague, but I'm having trouble finding the words to explain it at this moment.
Murray for a short time used more of a lawnmower styled gearbox at the front of their main steering rod which in theory is great but makes for very slow response times and the gears wore out over time when not properly lubricated or from extended use. We've had to fix these assemblies over and over, you can occasionally keep the system and weld a large fender washer behind the assembly so snug up the gears, but if worn beyond that you must cut out what gears are there and attempt to emulate other kart's steering.
If you need any pictures to aid in this please ask and several members will be happy to post them, additionally i'm sure if you browse builds you'll be able to see what they've done with control arms etc.
