Yes, yes a pod filter, that's what I meant...
by cold air intake, I meant this...(with the pipe and everything...)
http://www.hpautoworks.com/images/aemCold-Air-Intake-copy.gif
Iv'e seen some mini-bikes with one of those on, I just thought I could get some decent added power out of one of those...
Could I apply any of these modifications to my engine?
Timing Key - Increases your engines timing by 10 degrees, cheap and VERY effective part, But please note this increases performance on some engines, but can also decrease performance in others, it depends what your timing is set at in the factory. (RRP $20)
Fibreglass Reeds - Replace your stock metal reed with a high performance Fibreglass one. Fibreglass reeds allow more and faster fuel into the carb, this resulting in a faster burning of fuel, which increases low, mid and top end power. (RRP $20-$30)
Performance Air Filter and V Stack - If your bike came with a black air cleaner instead of an air filter, its loosing potential power, by adding a high performance air filter and vstack your allowing more and faster air into your engine, which will increase performance and engine life. (RRP $30-$40)
Hi Flow Fuel Filter - This is not a performance mod but it is one of the most important things that should be considered when buying modifications, If your fuel line does not have a fuel filter, there is a very good chance that dirt or foreign objects have got inside your fuel and are now blocking your carb. By installing this cheap modification it protects your engine from harm by dirt, plastic, etc. It is a must for every bike . (RRP $7-$15)
