new guy needs help
eastereggsrus
Hello everybody I'm new to go karts I always wanted one everysince I was a liitle kid I'm 21 now and decided I'm gona get one so I found a nice one on craigslist for 50 bucks it had a honda 5.5hp ohv the guy left it it the raain and messed with the motor so I replaced it with a new harber freight clone 6.5 and changed the back tires to one step up well I put the old clutch on it and at first it wouldn't even move the clutch was frozen so I worked with it so now it rolls and fierd it up and it hauled *** but the clutch startted smoking nd now it doesn't run, I figured it was cause the clutch was old so I'm tryin too find a new one to fit my kart, my cart has small wagon wheels from harbor frieght and a little bit bigger onjes on the back the back sprocket is big and is almost the size of the front tires and the back tires are for like a wheel barrel or something of that sort just wonderin if I should change sprocket size cause of the bigger back tire even though its not that big and wat clutch would best fit my need and where's the cheapest place to buy em?is comet clutchs any good? There like 30 on ebay, and how do I find my chain size? So far I put a little high performance air filter and a little muffler from a mini bike and is there any other little mods I can do to get a few more hp or mph? I don't want to much mph cause I like the torque, sorry for rambling I'm at work and am bored and sorry its just one long paragraph I'm on my phone and can't figure out how tob space it
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
First, tell us the diameter of your rear wheels. We also need to know the number of teeth on the clutch and axle sprocket. Those HF dolly wheels are no good, you'll shread them in a tight turn. Post up a few pics of your kart. These engines have lots of mods. There not really worth it though, especially if you care more about torque than speed.
eastereggsrus
Ill let you now when I get home, where's a good place to buy cheap tires? I'm on a budget iso I'm not about to spend a fortune on a go kart you now wat I mean
eastereggsrus
Ok the clutch is 12 tooth the sprocket I think is 60 thooth it was kinda hard to count, the rear tires are 12 inchs tall and the front arre like 8 or something like that, when I got it it had small tires all around and it was really low and the sprocket almost touched the ground those tires were thrashed and I happen to have a pile of those tires in my backyard so I just got some intertubes and put on bigger tires I'm only 120 pounds I think this motor has tons of torque maybe to much and id like a little more top speed but not so much its gona take me a mile to get there, I have some go kart wheels there wide and nice but they don't really work on it I tried to make it work but its just not happenen
redsox985
PA
I don't want to say higher ratio or larger tires because you are smoking the clutch, but that's the easiest way to gain speed. Maybe a heavy duty clutch and higher ratio? Pictures of the kart and clutch and all would be very helpful.
eastereggsrus
Sorry for the hufe pigs I havnt figured out how to resize them but you get the point, I think I just smoked the clutch cause it was extremly old and if was rusted shut when I got it
redsox985
PA
That may be it. It's also way out of alignment. Does it ever throw the chain? Those tires are a good size and your ratio is good, too. Try a new, quality clutch.
redsox985
PA
On a side note, blur has nothing to do with resolution. Lower res may look clearer because there's less detail but a higher res photo, when shot stable, is much better than a stable lower res photo. Anyways, adding a few teeth to the rear can't hurt anything but your top speed. If you're ok losing some speed then a larger rear sprocket and new clutch would do well.
redsox985
PA
That you will. You'll get off the line first but may get smoked in the long run.
eastereggsrus
Sorry i. Took the pics with my droid and this thing is colnfusing lol you really think I need a bigger sprocket? This one is close enough to the ground, and my front tire alignment is off but the back chain. Is perfect it just looks that way in the pic, wat clutch should I use? And where should I buy it at?I'm not lookin to spend a hole lot maybe no more then 50 if posible, and how do I tell wat chain it is? A lot of sites say 35 or 40 chain wat is mine? And is there a way I can set the governer a little higher? Not a hole lot just a little I don't want to take it off, if I mess up this motor I got the 2 year warrenty so this is my experimental one lol I don't think I'm gona mess with the gearing I like it for now anyways
eastereggsrus
Now that I look at it I just remember I took off the chain to mess with the clutch so that's why its out of alignment, the motors not bolted down tight, and a nother question wat bore size is it? Is it 3/4? Thank you for all your help, now I just need to weld up my muffler and put on the air filer and ill be sset
Bluethunder3320
okay, take a ruler and measure the diameter.
if its 3/4 inch then 3/4 bore. you get the idea. if there is a clutch blocking it then you will have to take it off.
im pretty sure its 3/4 though thats most common
eastereggsrus
Ok I so should I get a comet clutch for about 30? Or a maxtorque clutch for about the same 30ish or a hillard or something like that high performance clutch for like 45ish? I'm going threw ebay
eastereggsrus
Miine is a 3/4 bore 12 tooth I think 35 chain, so should I get comet or max torque? There the same price and I can't seem to find any info on them just want it to last a while on a lightly modded kart thanks everyone!
redsox985
PA
12 tooth is almost always 35 unless it's a racing clutch. And a 60 tooth sprocket is usually 35 because in 40 it would be HUGE.
