New guy, motor question
T3clay
St. Charles MN
Hey guys, I'm new here and want to build a kart for my son and I in the near future, we want a cart to drive offroad on trails gravel roads campgrounds ect. My question is how big a motor would you reccomend so that we can get a decent speed and hill climbing ability.
Would a 9hp have the power?
I'm excited to start the project!!
Thank you for the help
9hp will be plenty of power; there are loads of karts running on the 212cc, 7hp Predator engine without a problem.
As for the hill climbing aspect, I strongly suggest you use a CVT (torque converter) over a centrifugal clutch with somewhere around 6:1 - 7:1 gearing (depending on weight & tyre size).
Good luck with your project, be sure to start a build log &, of course, let us know if you have any questions :thumbsup:
Oh & remember, there are no stupid questions...
dnuccio
AZ
if you dont want to spend the coin for a torque converter, you could always run a jackshaft setup with a centrifugal clutch. obviously the TC is alot better, but the jackshaft costs probably half as much depending where you buy your parts.
A jackshaft only gives you the ability to create a lower geared system but, it's still constant. A torque converter gives you variable gearing &, therefore, the ability to climb hills while still achieving a decent top speed
dnuccio
AZ
right. i was just suggesting the jackshaft in case he didnt want to/couldnt drop the money on a torque converter.
modelengineer
Lord of the noise
Sydney, Australia
If you can find a written off motorbike for cheap that'd get you more power and a manual gearbox. Depending on how old your son is that might be a better option.
I'd recommend a 250cc if he's old enough to control the power.
T3clay
St. Charles MN
If I was going to put a 550 in a kart would that be too much power? Too much weight? Too much fun?
Been looking on craigslist and I see there's lots of options out there
Really depends on the kart. You may be okay with a well-built buggy or a full-on race chassis. On a fun/yard/concession/crap kart, it's a Darwin Award waiting to happen.
T3clay
St. Charles MN
Wow that's crazy, how difficult is it to rig up the shifting/ gears on a cart like that I have done some work on mini bikes but only with jack shaft kits never with shifting ect
dnuccio
AZ
just have to mount a shifter and a linkage/cable. and depending if you get a semi-auto one or not you may need to set up a clutch pedal.
