New guy here: wheel question
Aomiracle
Warren, Michigan
Got a kart recently got it running perfect had some fun with it and discovered all 4 tires are bad. Tires on it now are 13×5.00-6 on split 4 bolt rims. Probably going to put the same size tires on the front, but I want to put larger ones on the back to give the chain some more clearance and get more traction. What's the largest tire I can put on the same rim? Will be used on and off-road but mostly on concrete. Thanks :D
Kansas City, Kansas
Biggest I've seen for a 5-6 rim was 18"
Keep in mind changing to a bigger tire will greatly affect you spped, torque, and strain put on you clutch.
What is the gear ratio and what clutch do you have? (centrifugal or torque converter)
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
That kinda depends on your clutch or torque converter as well as gear ratios. If you have a centrifugal clutch a good rule of thumb is 15" max. Count your teeth on axle sprocket and clutch. Divide the two to get a gear ratio. example 72 axle /12 clutch= 6:1. This is a good all around gear ratio. Anyway I think you can get 16x6x6 tires for six inch rims. Turf saver tires make a good tire for general use light off roading and good on concrete.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Thanks for the advice. Has a centrifugal clutch I'll check gear ratio tomorrow. Think 15×6-6 would work for a standard gear ratio?
Yep:thumbsup: I have 15x6x6 on a kart with the 6:1 in my example. No problems burning any clutches and spins tires for donuts (180*s) in the dirt.
