Picked up a kart for my son this weekend. The spindles have no caster to the them (they're vertical) and the kart actually appears to have the ackerman reversed - the outside wheel appears to turn more tightly than the inside wheel. Control arms are forward of the spindles and point straight ahead. Linkage at steering shaft is via two link points, not one stacked upon the other. Also, the right-hand tie rod is much longer, almost 2x as long as the left. I'll get some pics of it later on.
It's not so bad right now that I have it dialed back to a relatively slow speed for him to get used to, but at higher speeds, it's very twitchy and tends to plow straight ahead (rather than turn) in corners. Wondering how I can fix it to make it more manageable?
