What info??? Ask a question dipstick...
He didn't want any info, he provided some about jackshaft setup and was wondering why nobody (XXXStevemanXXX) commented after asking for it. No need for name calling I think.
That's just the normal poking of fun around here![]()
To some Extent
What ratio would you say im running ?
Id say im able to go up any hill i want
Dont know yet it needs a fuel pump right now its using one thats a pulse pump that is activated by something in the motor that pushes the button on the bottom of the pump But its not working .The pump needs to be rebuilt so i went out and bought a 6 psi low pressure electronic universal fuel pump. It's hard to get the last numbers for the tooth count when there behind a plate so i took a crack at a guessing the tooth count i went out there pulled the plate off and counted 15 to 23 on the chain coming off the jackshaft going down (Right side) then on the left side it comes out and goes from 10 to 30 .Assuming I got your numbers right into my Excel spreadsheet calculator (I like doing things myself, I come up with 5.52:1. With 24" diameter tires at 3600RPM, you should be going over 46MPH. That's not factoring in the torque converter ratio which should add even more speed as the RPM goes up.
With 31HP and the torque converter, you can probably climb trees with it. Will it pull the front wheels off the ground on take off?
Is that (in pic 4) a diff or gearbox of some description? What is its internal ratio?
