New Go Kart
gaspipegokart
Wisconsin
Hey guys! My neighbor just gave me a go kart that was made out of a golf kart and this thing is really cool! I just want to know what kind of engine I should put in it to get it up to maybe 40 mph. He was going to put in a 16hp engine, but what do you you guys think?
gear monkey
Tn U.S.
you should look up a horse power to cc conversion most golf carts are cc.as for your speed depends on weight of kart, driver, and aerodynamics. also a torque converter should help speed. when you decide upon a engine get a briggs an straton not a chinese knock of clone moter.:thumbsup:
there is no such thing as a HP to CC Conversion!
I have a 125cc 42HP kart sitting in my garage and a 200cc 6.5HP engine in my basement.
Also I have a 500cc 46HP Motorbike and a 3000cc 220HP car.
But yes, that kart looks heavy so I'd suggest anything above 9HP
to get a decent speed with a CVT [aka TC] (looks like the driven unit is already mounted ;))
'maybe 40' ? Hmm.. maybe 13HP ?? Depends on actual weight of kart plus driver, and size of your rear wheels (as in overall gear ratio)
Check the speed calculator:
http://www.diygokarts.com/speed-calculator.html
to see what gear ratio you'd need.
with that and the kart weight (aproximated ;)) someone might have a more educated idea what exact Poweroutput you should look for.
Im going to add to the HP to CC confusion, Ive got a(5.2 v8) 5200cc w/140hp in my current car, my previous, had 2.2i4 w/140hp, Of course torque values are really different.
firemanjim
Just kartin' around....
Houston Texas
:smiley_omg::smiley_omg::thumbsup: Man,that kart is SREAMING ATV/QUAD engine w/reverse..... ! That is an AWESOME :bannana::bannana::bannana:SCORE! FREE is ALWAYS for me!
Seriously, that size kart needs multiple gears to be fun. I really dont think you will be happy with 13hp @3600 and a CVT . I'd go with like a 200-250cc quadeengine, but thats just my opinion.
Now the odd part:
Torque is the same if HP is the same, since HP is torque over a timespan.
(HP can be measured in Watts, Torque in Wattseconds aka Newtonmeter)
But you're right, it's a difference if you have the power at idle or at 4500rpm ;)
Not necessarily (I know, we've had this argument before):
HP = torque x RPM (IN IT'S SIMPLEST FORM)
If you have two vastly different engines that produce the same HP, either one produces torque a lot faster or the torque peaks at higher RPM.
In 1996, two particular cars were released in Australia; a Toyota Camry, powered by a 3 litre V6 which produced 151Kw & a Holden Commodore powered by a 5 litre V8 which produced 185Kw. In the grand scheme of things, that's not a big difference so, why such a low number on the V8 & such a high number for the V6.
The significant difference:
V8: Single cam, 2 valves per cylinder
V6: Quad overhead cams & 4 valves per cylinder
allowing the V6 to produce more torque in a shorter time...
...& here's the kicker: By making moderately small changes like, larger valves, higher capacity fuel injectors, modified cam profile, etc, you can produce even more torque.
When junior members ask "how do I get more power out of my 200cc clone engine" the first thing we suggest is a high flow air intake & exhaust. Why? Because that allows the engine to breathe &, therefore, produce more torque. The next step is to remove the governor: Why? To increase the max RPM &, possible, open up the top end of the torque curve...
problem with clone engines is the are :censored: HORIBLE
In your opinion. However-
They are insanely popular, and used in racing. If they all sucked that badly, they wouldn't be. Some clones are better than others.
Not everybody can afford a brand name engines. If I had my choice, everything I owned would be powered by a Honda GX series. Do you know that I can buy FOUR clones locally for the price of ONE Honda GX? Sure- the Honda is superior. But don't be too quick to condemn something you're clearly not that familiar with.
In addition to the bike/quad suggestions, a sled engine and CVT combo would wake that thing up, too.
firemanjim
Houston Texas
I agree about the clone motors..... I was REALLY skeptical about the predator motor but after having one, I HAVE GOT TO SAY its been the best bang for the buck, kart wise, in a while. I will be buying a couple more for sure.
And you're correct, a snowmobile power plant would be a great choice as well. I've seen them from stock (fast) to wild (SCARY fast as H€¿¿):stir::thumbsup:
meyerside
Josh, Larry said he would sell you the 16 hp motor. We should talk if that's something you are interested in.
firemanjim
Houston Texas
hey just asking does anyone know how to extend a steering wheel
IIRC, you have 2 threads going already, no sense in asking atotally unrelated question in someone else's thread...... and if you can't figure out how to extend a steering shaft, you might SERIOUSLY consider getting some help with your kart build..... I'm just sayin......
