I'm sorry if this is on here somewhere, but I've tried searching and can't find quite what I'm looking for. I'm probably am not using the right terminology or something.
My friend just bought a 200cc Road Rat Racer XR AKRA which you can see here. http://www.saferwholesale.com/200cc-Road-Rat-Racer-XR-AKRA-p/rrm - xr akra 200cc.htm It has a Lifan 196cc and says engine family ACLGS 196168
Anyway, he got this thing without any owners manual at all. He went to try to start it and it wouldn't start. After raising the rear wheels, it will start, but if we push in the brake, it kills the engine. Also, there is an arm under the gas tank with a longish spring attached to the arm, but the spring isn't attached to anything on the other side. I have a picture of the arm and spring you can see here. http://www.aaronhull.com/misc/GoKart/GoKart03.jpg Unfortunately because it's the weekend, we cannot get hold of anyone where he bought it.
What is the arm for and what should the spring likely be connected to?
How can we adjust the clutch so the go kart can stop and yet continue running?
There are 2 screws on the carb, one with a spring, and one that is more like a set screw. What are each of these?
Are there any manuals online anywhere for this thing?
I'm sure he doesn't want to hear it, but how badly did he get taken buying this thing?
I'm not a small engine guy, but I'm fairly mechanically inclined so don't be afraid to get technical.
Thanks for any help!
