new engine
slideways
That's true. Let us know what you are hoping to achieve with the new motor. Is the old one clapped out or did you just want something with more power off the line?
For example. A 6.5hp clone for $99 with about $75-100 of basic mods will get to you the 9-10hp range easily. But if your Briggs isn't worn out you can get close to that as well.
slideways
anderkart
Surprise Arizona USA
I have a manco go kart with a 5hp briggs, what I want to do is buy a new 11 hp engine. It looks like all of the 11hp engines I have looked at have a different size shaft so do I just need a new clutch/sprocket? Or is there more to it. any help would be greatly appreciated I am totally new to this
Besides needing a 1" bore clutch, the 11hp will most likely have a larger motor mounting bolt pattern.
If your considering an 11hp/GX340 Honda (or a copy/clone), you might as well spend a few bucks more and get the 13hp/GX390 model, they both have the same dimensions and weight.
Seether038
briggsman
Well the shaft on ur 5hp is 3/4" and on the bigger hp engines is going to be a 1" shaft. Clutches are expensive for the 1" clutch. I would just play around with the gearing on your 5hp and maybe tweek it a little bit before you go dropping the coin for a 11hp engine(just because its got more power dont mean it will go faster). You maybe surprised with how much you can get out of that little 5 and the right gearing for what you want the kart to do. Hope this helps!
Blazkowiez
Kart Aficionado
Houston, Texas
They do make some larger engines with 3/4" shafts that fit karting purposes more readily. Is there a specific reason you want to jump to an engine more than twice the size of the one you have on it?
In case you had this thought, I will point out many people have a silly belief that if their kart has a 5hp engine that goes 30mph, a 10hp engine will make their kart go 60mph... this is far from the fact.
