New Engine
D_CLARKE
Buying a new engine for my yerf dog 3202 Need to know what will fit it. want to get the fastest engine possible but not spend a TON of $ right now it has a honda clone 6.5 with no starter recoil because it broke
Getting a larger engine could mean a lot of fabrication work. larger engines mean a larger footprint. You will have to drill new holes in the engine mounting plate, or fab a totally new one. Larger engines have 1" output shafts. This means a larger bore clutch which costs over $100. If you have a torque converter on your engine, it will probably not be suited for a larger engine.
Why don't you just fix the recoil on the engine you have now. It is going to cost loads less than trying to buy a larger engine, adapt mounting plate, and potentially buy a expensive clutch or TC
Oh...and post some pics of your engine, and clutch. It is difficult to answer questions without pics
D_CLARKE
Cannot find a starter recoil that fits the engine (Harbor freight greyhound 6.5) i just wanted to scrap it and start new
r_chez_08
Should be in the shop...
Cornwall, UK
:mad2::mad2::mad2:
OK then, send the engine to me. I will fix it.
Or you could buy a new starter for like $15! Take a pic of the recoil pulley on the flywheel, I will send you a link to a starter that should fit.
You can get quite a lot of power from these little clones for not a great deal of money.
$50 will get you around 8-9hp and 5000rpm.
another $120 will get you the safety of being able to rev to 6500rpm. Not required if you like to live life on the edge!
$50 will get you a nice camshaft, with a powerband from 2-6k, and an extra hp or 2
$15 plus some time will up your compression ratio
$2 gets you a nice reliable spark plug.
You can then alter your gear ratio for more torque or speed.
However, if you really feel the need to get a new engine, HF sell a 420cc engine (13hp+) for $349. You will then either need to spend atleast $100 for a clutch, or atleast $300 and some fab time for a torque converter unit. Then there is the issue of a different mounting footprint and the possible clearance issues. Overall it will cost over $400 and require additional fabrication. Whereas you can see here for well under $400 you can build 11+hp out of a lighter clone block. This can be done by any DIYer with a torque wrench and a bit of time.
Do NOT just scrap that engine. If you really want to get rid of it, I am sure someone on this forum would give you a few $ for your time and shipping money.
D_CLARKE
Well my kart is at my friends house it is a greyhound 6.5 blue engine it also just cuts out when i drift it in the dirt.... what could be the problem
