OK then, send the engine to me. I will fix it.
Or you could buy a new starter for like $15! Take a pic of the recoil pulley on the flywheel, I will send you a link to a starter that should fit.
You can get quite a lot of power from these little clones for not a great deal of money.
$50 will get you around 8-9hp and 5000rpm.
another $120 will get you the safety of being able to rev to 6500rpm. Not required if you like to live life on the edge!
$50 will get you a nice camshaft, with a powerband from 2-6k, and an extra hp or 2
$15 plus some time will up your compression ratio
$2 gets you a nice reliable spark plug.
You can then alter your gear ratio for more torque or speed.
However, if you really feel the need to get a new engine, HF sell a 420cc engine (13hp+) for $349. You will then either need to spend atleast $100 for a clutch, or atleast $300 and some fab time for a torque converter unit. Then there is the issue of a different mounting footprint and the possible clearance issues. Overall it will cost over $400 and require additional fabrication. Whereas you can see
here for well under $400 you can build 11+hp out of a lighter clone block. This can be done by any DIYer with a torque wrench and a bit of time.
Do NOT just scrap that engine. If you really want to get rid of it, I am sure someone on this forum would give you a few $ for your time and shipping money.
