New Engine Break in. (Sorta)
Ryafor
So I got a new engine that I plan on using for a go kart. Here are the specs not that I think they matter.
208CC OHV CHAMPION 7HP ENGINE
- 4 stroke 208cc Champion OHV horizontal engine
- Easy pull recoil start
- Max 3600 rpm
- 8.1 ft.lb. at 2600 rpm
- 8.5:1 compression ratio
- 0.63 quart oil capacity
- Low oil shut off
- 0.53 gallon fuel tank capacity
- Counter clockwise shaft rotation
- 3/16" shaft keyway
- Applications:
- Pressure washers
- Compressors
- Go-Karts
- Log splitters
- Chippers/shredders
- 1 year limited warranty
Anyhow my question is.....
The engine isn't in a go kart yet and won't be for a couple months. The throttle isn't set up or anything yet. I think I can figure that out on my own. Before I go getting rid of the box and packaging etc I wanna start it up and make sure everything is working alright. If not I'll return it. Would it be ok to just put gas and oil in it and leave it running for an hour or 2 or a few full throttle or half even or even just at idle? What I'm asking really is because it isn't on a go kart yet I really won't be using it but I do wanna make sure everything's working good so how do I go about it without it being on a kart yet that's being used?
---------- Post added at 06:46 PM ---------- Previous post was at 06:45 PM ----------
I could go out ever 20 mins or so and adjust the throttle lever here and there if need be
