New DIY stinger pipe
n3480h
NW Iowa
Never having been good at leaving well enough alone, I decided the Fox II rebuild will need a stinger pipe. Have some 4130 3/4 x .063 tube left over, and an empty jumbo paint rattle can. Used a small drill poked through a blue shop rag and drilled out the valve. There was still a little pressure left in the can, but not enough to make it out of the spray nozzle. Followed the small drill with a 3/4" hole saw. Heated the 4130 tube and bent to 90°then inserted one end about 3" into the can and welded it. Welding steel as thin as a rattle can is a challenge - we won't go into how to fill holes with oxy-Acetylene. Then welded a tab for a brace to the tube. With that done, a pattern of 1/4" holes was drilled in the bottom of the can. Tomorrow I'll mill a mounting flange to match the engine's exhaust port and studs. Then it's on to a new intake.
I know I could have probably bought a stinger exhaust, but DIY was more fun, and the part cost me a couple small welding rods and a little gas. Cheap is good, right?
2SlickNick
American Minibikes @ FB
Mesa, AZ.
That looks so cool! I can't wait to hear how it sounds.
Didn't realize the rattle can were steel.
Maybe I could do the same with my flux core. I have done thin metal with it. I just use my low heat setting, fast wire and travel speed.
Might try welding some cans soon then for practice.
:iagree: Looks mean nothing if it sounds like crap...
For best results welding thin metal, TIG is the favoured method but, when using wire feed, many short 1second bursts provide a better result than one long burst
n3480h
NW Iowa
It may well sound like crap. But it'll be a better crap than the "puff puff puff" the EPA muffler makes. Just having fun with a welding challenge.
