New clutch smoking
raposak
2012 Build-Off Winner
Howell, NJ
Well I just took my first of 3 new carts for a test drive tonight in a light dusting of snow and the clutch was smoking like crazy. I'm running a 7hp predator stock, 10t clutch and 60t sprocket with 15" turf tires. All my calculations show that with this setup, a 6-1 ratio should be good. The kart is light but i'm about 250lbs.
I was doing a lot of donuts and feather the gas around obstacles. I ended it with 2 high speed runs up my block. The kart flies in the street. When I got back, the clutch was smoking something fierce. The paint on the outside of the drum melted/flaking off where the clutch engages. Just wondering if there is something wrong or could it be just a new clutch burning off the paint from the factory.
Any input would be appreciated. I would go with a TC, but it would be very difficult to fit it.
raposak
Howell, NJ
I have the hilliard extreme duty clutches. They engage at 2300 rpms. I'm wondering if I replaced the springs to engage at 2000 or even 1800 rpms would help. That way it is engaged when i'm feathering the gas rather than just slipping. Watcha think?
Feathering the gas will cause the clutch to slip, but I think you have a greater problem with your gearing being what it is. ^:1 is a good ratio to start with, but when you start using tyres that are 15" tall, you are going to start having problems at that gear ratio. You are also 250lbs which makes the kart heavy. I would suggest gearing down further to 7:1 or 8:1,
raposak
Howell, NJ
Really, i'm not fat, i'm fluffy....... I guess I won't change anything yet since these are built for my kids which are a lot lighter. I may have to change the springs on my 6 year old since I want to limit the throttle so he can't go balls to the wall but still want it to engage properly.
Kaptain Krunch
Pro Junk Collector
vermont
I had a kart geared 6:1, kart was probably 175lbs, it did good with me on it (155 at the time). However i burnt up a clutch in 2 inches of snow, and it didnt like steep hills. I'd say you need to gear it down if you plan on riding it.
exenos
Project Nut
Snow just kills karts. Any thing more than 1.5-2" of snow will almost stop you dead. Its the single ratio thing.
