New Cart
freakboy
the names 'mater
hick town
Yeah i would do as kenny said to cause if its worth some thing you would be better off selling to a collector on ebayand then getting a new frame to cut up
redsox985
PA
I think that you could have the title of 1st zero-turn go kart on DIY. With proper ackerman, that thing would corner like a puma lol.
YungVick
Cool Thanks Everybody For Your Ideas Since Ima New To Diss G KArt Thing Ima Start Off With OneEngine Probly Like a 6.5 Or 13hp Depends On What I Find First O Another Question About Back Tires Do Can RACING SLICKS Go On A Dead Axle If So I Can I Find A Set With SproCket On Them?
YungVick
Cool Thanks Man Yall Been really Helpful One More Question I Just Bought a Hub With A 72 Teeth Sprocket On It Whats A Good Number Clutch Teeth Too Get forBetter Proformance? Ps I Just Order Da 6.5 Clone From Habor Fright Ima Keep Everyone Posted On Every Thing Pics Coming!
r97
Measure twice cut once
Massachusetts, USA
guessing you sprocket is #35 chain and that youl get about 12" tires a 12tooth #35 chain cent clutch with 3/4" bore is the ticket, unfortunatly with a cent clutch you sort of stuck in the 1 to 6 gear rateo range. if your realy intersested in boosting preformance i wound suggest a torque converter but at about 180 bucks you may not be intersted. another way to boost preformance is takeing out the gov but that would be for some one whos taken a part an engine a few times
