New Cart
YungVick
Hey..Whats Up DYIGoKarts...Im New To The Go Kart World But I Know Alot About Mini Bikes...Recently I Checked Out My GrandDads Garage And Found A GoCart In There I Pulled It Out And Checked It Out Its Pretty Cool He Said Its Been In The Family For While Now And I Want Too Rebuild It But i Have No Idea What Too Do It Look As If It Adapted For Two Engines It Had One On There Already But It Was Trashed So Ima Upload Sum Pics And I Would Be Very Happy If Yu Guys Could Throw Sum Ideas At Me About It..Take In Mind Ima SPEED Freak lol So I Want Fast Ideas Thanks Alot!!
Ps I Already Did A Gloss Paint Job On It!!
[/IMG]
[/IMG]
New Paint!!
[/IMG]
[/IMG]
lol Lil Bro Tryna Help Out
[/IMG]
redsox985
PA
I'd suggest a big shifter bike/quad/snow mobile engine for your speed addiction...and a bucket seat. Oh, and you don't need as many letters in caps. :p
r97
Measure twice cut once
Massachusetts, USA
pop in a live axle(if it doesnt have one yet 2 sprockets then throw in 2 engines. make shure you have the engines spinning at the same speed or you could loose performance
fowler
Bullsbrook West Aus
dosnt this rely alot on finding a clockwise and anticlockwize motor
its 11:30pm here and i cant be bothered working out which one is hard to find
redsox985
PA
Just mount them with shafts facing the same side. Rig throttles to work. Or use a dead axle and two throttles and make it like a zero-turn mower. Independent throttle control to each wheel. (That's just a ridiculous idea)
r97
Massachusetts, USA
actualy thats an awsome idea it would help with going around corners to but youd have to keep them at the same speed for the most part
YungVick
It Already Has And Dead Axle So I Think Ima Go With Da Twin engine With Sprockets On each Back Tire and Two Throttles But Im Still Kinda Confuse About The Right Side Motor Mount
r97
Massachusetts, USA
if you do what your planning on doing youl need an engine that spins clock wise and an engine that spins counter clockwise, the other option is to put in a live axle with one sprocket in the middle(coming from the engine mounted on the right side) of the axle and one sprocket next to the left tire. your third option is to keep everything the same put one engine on normaly on the left side then turn the other engine around but a reversing gear box on its shaft going to the wheel on the right side so both wheels spin in the same direction
freakboy
the names 'mater
hick town
Just cut the dead axle stuff off and then make it a live axle then mount 2 normal turning motors the same way and run clutches to the axle and be done with it... simple effectve and will be done quicker then it will take to find a backwards running motor..
