New cart, wheels?
mlipnickwc
I recieved an old Carter Bros go cart frame and a unknown hp (guessing a 5) Briggs and Stratton Engine for free. I have recently dissassebled and painted my engine, the block is red and the covers are white. Put it back together and its still running great. I plan on putting a straight pipe and a custom intake with a cone filter.
The only flaw on my cart is that the wheels are pretty small. The back tires are the size of a handtrucks wheels, and the front i would say the rim is 4 inches. So ive decided i want to put bigger wheels on the go cart. I have 4 lawnmower front tires and i want to use them as the new wheels. I got the fronts all worked out, i know what i am gonna do for them. My issue is the backs. The lawnmower tires have a hub built into them and the originals were 2 pieces and the hub with sprocket bolts it together. How would i attach the sprocket to the rim of the lawn mower tire? The built in hub is centered in the rim and around it slopes up, so i dont know how i could mount anything to it.
Wow that was a book, sorry haha. If anyone wants to see any pictures, let me know and ill go out tomorrow and grab a couple.
RobertD
Administrator
Texas
yeah, let's see some pics... you can get these mounted no problem if you're got a certain size of rim. I assume it's a fixed rear axle, not a moving "live" axle?
mlipnickwc
The axle is inside of a tube and sicks out at both ends. The other thing i am worried about it the axle not being long enough, is it easy to replace the axle in one of these?
RobertD
Administrator
Texas
Sure, you can just grind it off and make a new one, so long you get it nice and straight!
