no whereman
hello forum.i am building a 3 wheel go cart type conveyance.the motor is a 208 cc powerhorse electric start. I am going with a single wheel drive setup.my question is ,will a single flange flange 2 pc split wheel be ok for the drive sprocket and the drum for a band brake?and will there be any harm in using the same wheel on the non drive side if I should choose double band set up?the parts sellers seem to know absolutely zero about anything except money.oh yes a little more info on design,this is for an amputee so the seat needs to be 20 inches at least from the ground so a widesh axle is in order.longish wheelbase 12 tooth clutch 72 tooth drive sprocket.i am aiming for a cruising speed of aprx.12 to 15 mph at about 2600 rpm.any thing ive overlooked?any advice is much appreciated thanks
(check my location)
