Need to raise engine up...
Jedibrad
Franklin n.c.
Hi y'all...need some advice on raising engine about 1" to allow for clearance of header pipe and breather adaptor. Can I just using some nuts under engine with some longer bolts? Build is on a mini bike
I'd rather have the engine on a 2x4 than just resting on the nuts.
Tubing is the way to go.
Randy H
They are from Briggs. Arguably a very good way to raise an engine 1". But what do I know? I find ways to lower stuff.
Atlanta, GA
Makes me wonder if anyone has ever "hung" a small engine, instead of using the bottom mounting plate. Maybe using the tapped holes for the gas tank.
