need specs
motor_head
expert garbage picker
sutherland IA
if anyone has a book for opposed twin briggs engines I would appreciate it if you could look up the reject size for the rod journal on the crank
400707 1220 01 89030312
thanks
motor_head
sutherland IA
thanks for the interest,
i pretty well covered the question
i thought i had a book but i don't, i spec'd it and it was like 1.?18 and 1.?20 can't remember off the top of my head. has light score marks but it should smooth up alright
it's not good when you pull the motor apart and find the oil splasher has all the gear teeth stripped off and a few other bits broken off
most of the motor is surprisingly good bores are good all other journals and bearings show no abnormal wear just the rod bearings. Would be nice if it just needed new rods rings and an oil gear
