Need some tips/advice
HellSpawn
Wadena, Minnesota
18hp B&S IC buggy build.
New guy here I guess, Looking for some tips & advice on building a decent off-road buggy/kart.
I've been using Google Sketchup to throw down a rough design, I am unsure of how well this thing would hold up if I decided to stick to it.
I'm intending on using a 18hp B&S IC powerplant (perhaps an upgrade to a much larger bike motor later on) and I want to know if this frame will support a decent amount of torque & abuse.
I've built my fair share of flat frame zero support karts, but I am ready to head into the big leagues.
solomon
ca
It would probably hold, but if u "triangle" brace it everywhere, it would defiantly be stronger.
HellSpawn
Wadena, Minnesota
Alright, I'll definitely take note of that for design.
I have a couple questions about steering setups.
#1. With a full independant front end, would I need some kind of telescoping steering linkage? or just something that pivots.
#2. A wider steering setup, all of my previous carts have had really short/tight steering. Any ideas on this? (I thought maybe a rack assembly would give me a lot wider range of steering, but I have no idea where I would find something small enough.)
Thanks.
HellSpawn
Wadena, Minnesota
Also need some advice on the type of steel I should be using, I previously was suggested to use 1"x1/8 square/round tubing. I am not sure how strong that will be however.
modelengineer
Lord of the noise
Sydney, Australia
You can shorten the rack from a Mk.I or Mk.2 Escort or an original Mini down to about 8" long. Might be a bit hard to find wherever you are, but it worked great in my sidewinder.
Kaptain Krunch
Pro Junk Collector
vermont
Tubing notcher...I made a little jig in my drill press with a hole saw and pipe vice, works ok. Need very low rpm.
HellSpawn
Wadena, Minnesota
Project is coming along very nicely, got a majority of my tubing cut to length & notched.
If I can find my old digicam I'll start talking some photos of the build!
HellSpawn
Wadena, Minnesota
Bit of an update!
Got the lower part of the frame tack'd up, heres a picture to give you guys an idea of the kind of clearance im going for!
HellSpawn
Wadena, Minnesota
I suppose I should create a thread in the photo/project log forum, unless a moderator can move this one?
anyhow, tomorrow's agenda includes fab'n some front a-arms & possibly some custom hubs for the front (I may want to do a disc brake setup in the front at a later date.)
HellSpawn
Wadena, Minnesota
Anyone have experience with golf cart rear ends?
I decided I was going to use the gas rear end out of my 99 EZ-GO (the frame on it was shot so its worthless)
Im just wondering if these rear ends are strong enough to handle a decent amount of torque & speed.
HellSpawn
Wadena, Minnesota
Haven't updated for awhile, got alot done however.
I also decided to go with a stiff front end for the time being.
I have somewhat of a picture of my rear end aswell, If anyone wants some closer pictures let me know.
