Need some help
kjs
Hey guys, I bought this used go kart for my son and the clutch seems to chatter before it eventually hooks up. It runs fine on flat ground once it gets going but wont go up even a slight incline. Im totally new to go karts and need a little help. The clutch seems fine I think? I've attached pictures. Thanks for any help2011-05-03 18.13.12.jpg
Put the kart up jackstands (all four wheels) and make sure all moving parts move freely. Maybe the brakes or bearings are binding.
Also- let's have a look at the gearing. Please do the following- Count the teeth on the clutch, count the teeth on the axle sprocket, and measure the full diameter of the rear tires, and feed us those numbers. Rider size/weight would help too, as well as whether it has a jackshaft (if so, include those tooth counts, too).
redsox985
PA
There's definitely a jackshaft in there. In his photo where you can see into the clutch's outer drum, you can see 2 chains. One from the clutch going up then a second going down to the axle. Count the teeth on the clutch, teeth the clutch chain goes to, teeth on the small sprocket of the second chain, and teeth on the axle. Also, measure how tall those tires are.
kjs
Thanks for the response! I'll count the teeth tomorrow, too dark now. I does roll fine though. I have to put a block under it when parked so it doesnt roll. Rider weight, my son 60lbs. me 180lbs. obviously does better with him than me but still slips on any incline. Thanks again.
