So I picked up a decent go kart frame from a friend of mine and i am looking to get it running again. It had a briggs and stratton 5hp motor on it but decided to buy a brand new 6.5hp greyhound motor (harbor freight). The engine fired right up second pull out of the box, it mounted fine, got the throttle hooked up good, I hooked up the chain to the centifugal clutch and to the sprocket on the dirve tire and now whenever I fire up the engine and as soon as i take the choke off my go kart starts driving on me and i have to hold the breaks to keep from rolling away. Does this mean bad clutch? It is an old 10 tooth hillard clutch I believe. If it is the clutch then I will buy a new one. Any recomendations? The axle sprocket has 54 teeth, I way about 160 pounds and would like a good combo of top end speed and good acceleration. Any help would be much apreciated.
