Need some help with gear ratios!
CWarner
Central Illinois
I have a go kart it has 16" tires, (I think) 9 teeth on the cent. Clutch ,and 60 on the sprocket on the axle. It has a 6.5 hp. (212 cc.) Honda clone. Is it possible to make it faster without sacrificing a lot of acceleration?? I just wasn't quite sure it was fast enough. P.S. this kart had a 5 hp. Motor on it but it went bad. So I would assume the current gear ratio is set up for the 5 hp. I'm also pretty new to all this Thanks!
Your ratio now is 6.6:1. With 16" tyres you are already at the limit on your ratio. If you make it any higher you will burn out your clutch. You might have to invest in a TC
9 teeth on a cent clutch doesn't sound right, can you please double check the tooth count?
Having said that, you had a 5hp engine, now you have a 6.5hp, that in itself will give you more torque, which equates to better acceleration; if that's still not enough, swap out the axle sprocket for a slightly larger one or do a few cheap, easy mods to the new engine to gain even more torque...
