need some advice over here
patrick824
I just finished installing my HF 6.5 on my cart. Its running with a maxtorque 3/4 12T and #35 chain onto a 72t sprocket. I hooked up the throttle linkage and drove it around a bit but seem to have a problem. I think the throttle is set up for use in something like a power washer or something because I have no "middle" output. Its like im idling, press the gas slowly in... nothing happens, then all of the sudden i just accelerate really fast... no in between. Like its got 2 modes, idle and haul ***. I am wondering how I can change this to let myself accelerate up to a certain speed instead of just launching and jerking around. thanks guys
Have you removed the governor? That will give you more control over throttle position.
I don't know just how much more control that will give. If everything's set up and functioning properly, there should be a smooth transition from idle all the way to WOT, even with the governor. I have several governed small engines, 2 on karts, 2 on riding mowers, 2 on push mowers, 1 on a generator, 3 weedies, 1 snowblower, and several other assorted. The governor is intact on each, and each throttles smoothly, including the clutch equipped units.
I think the problem lies elsewhere. Namely, a bad throttle linkage arrangement.
With nothing else to go on, I'm guessing too much slack in the cable, combined with a short pedal throw, or something along those lines. Got a pic?
If the governor is intact, make sure the throttle cable is connected to the proper throttle arm, not the carb butterfly. Secondly, with the engine off, slowly depress the pedal, making sure the cable begins to move the throttle arm almost immediately. Third, ensure that as you continue to depress the pedal thru it's range of motion, that the cable smoothly and proportionately actuates the throttle arm. Fourth, that the pedal travel allows WOT on the throttle arm. Fifth, that the pedal STOPS at WOT. Don't rely on the throttle to stop the pedal's travel, fabricate an adjustable (or fixed)pedal stop.
Lastly, ensure that you have return springs in place to positively return both the pedal, and the throttle arm.
