Brandon1023
needs an oil change
Ok, obviously a 2498 cc engine is not for a Kart
but I'm having a little mechanical trouble myself here. I've moved up to working on my car's engine, and in order to fix a timing problem, I had to pull the whole engine out of the car. Now that I'm putting it back together, the last thin stopping me is a shaft, stuck in the bolt hole for the coolant line bracket. Upon test fitting the bolts for the hose mount, I went ahead and tightened it until it snapped the head right off its little shaft. Hindsight is 20/20 and I can't do anything about it now, except try to get it out.
To make matters worse, I tried using a stupid screw extractor which went ahead and imitated the bolt itself, and decided to snap, leaving the hallow filled with marked steel.
I have tried almost every trick under the sun from cobalt drill bits to bits in the dremel. Not too sure what to do at this point, and I don't usually post on the internet for advice, so yea.. any pointers and appreciated at this point. Thanks. :rapture:
edit- Would it be possible to permanently mount the bracket on to the engine? I don't want to suggest this, but what about Rapid Fix (cyanocrylate ester) ? A guy at the parts distributor down the street told me they fix engine blocks with it. If anything, I could tighten the top bolt, and adhere all around the bottom. Then maybe, seal it with rtv like caulking? Just food for thought..
Anyway, thanks in adv.
