tinkerman73
Alright. I believe I am set on the idea of using the 7HP snowking. I have a belt clutch to go on there if it fits. I have a couple of pullies, but not many. I have a couple of gears, but not many. They are split between larger chain and smaller chain. But before I go trying to figure this hole lot out, I need to know what size pully and gears I should head for to make this thing go a decent speed(25-30). It is a larger kart and it does run lawn tractor wheels. I do not know the RPM of the motor. But, I can read off the size of the rear tires if needed. I know it will vary some. So, before we all get too deep into it, tell me better larger or smaller pully. Then larger or smaller gear on that rod? Then, larger or smaller gear on the live axle? Form there I can give a better list of what I have that corresponds in axle size. Then we can go from there. Then yall can beat me to death until we get it figired out and what I may need to buy(but hopefully not. Trying to do as low budget as possible). Thanks.
