need help :(
matty10
hi there brought a 100cc tkm racing go kart yday and a very fast lil thing but you can not keep it running you have to push it to start it and it will not tick over why do you have to push it and why wont it tick over i want it so you can just start it and sit on it and keep it running can sum 1 plz help on what to do and how to do it thanx alot matty
KieranM
Doin It!!
Kilkenny, Ireland
there should be a little screw on the carb with a spring (idle screw). turn this in and count how many turns you went in, then turn it out that many turns and slightly turn more or less untill you get a nice idle.
matty10
then it should tik over right ?? but still not the point why do you have to push it ?? its like it's in gear bt soon as you stop it stalls so myself i not sure cud it be the clutch may have been taken off
