abxcontracting
- Messages
- 2
- Reaction score
- 0
Piston locked up
Newer to engine building. Have a problem with the piston keep getting stuck a minute or two after idling.. here’s what I have done to the predator 212.
Dynocam cm grind cam
Arc ultra light billet flywheel
Arc billet rod 6254
Chromoly rods
Stock piston
Stock rockers
Billet side cover
26lb springs
Mikuni 24mm flatside carb
So recently I added the 24mm carb and the billet side cover. Since adding them is when the problem started with the piston getting stuck and not being able pull the pull start or anything. Drained oil took it apart checked everything, used mallet And block and freed piston. Everything looked fine. Everything moved freely. Put back together filled with 10w30 oil to spec, started. Idled for a min or two. Have a hair of throttle and stalled and locked up again. Prior to having the side cover and new carb it idled and ran.
Arc billet rod 6254
Chromoly rods
Stock piston
Stock rockers
Billet side cover
26lb springs
