Need help
Daniel Sheffield
San Antonio, tx
I have a problem. I have a tecumseh 5 hp engine that runs but when it gets hot it loses power, then eventually dies. What could be the causes. Have pics on my page. Won't let me attach here with my phone.
it could just be over heating
That's what I'm thinking; when metals heat up, they expand, making tolerances (the gap between moving parts) smaller; when those tolerances reach zero, that's when engines seize...
Would a oil change help. From what I understand is that it sat for a while.
...& you didn't change the oil? For all you know, that oil could've been in there since the engine was new...
Oil is full though.
How full is "full"? It's possible it's overfull
Daniel Sheffield
San Antonio, tx
No it's within the crosshatch marks. Finally got it working after complete carb cleaner. Oil is next though. Just wanted a test. Drove for about 10 min before problem.
Daniel Sheffield
San Antonio, tx
It is governed. But not sure if it is adjusted right. How do I adjusted a governor.
---------- Post added at 04:31 AM ---------- Previous post was at 03:54 AM ----------
Governor rod is also loose and leaking a very small amount of oil. Normal?
Poboy kartman
Senior Moments Member
White Settlement Texas
Surprised no one has mentioned this: although I've never happened across it, it makes sense that your valve lash is too tight. When it gets warm the valves don't fully close causing it to lose compression and power.
Daniel Sheffield
San Antonio, tx
How would I check this. I don't have any gauges but a micrometer. Also plan to start a thread on the brakes.:mad2:
Poboy kartman
Buy a blade type feeler guage for a few dollars...then Google up..(or search here)....for valve lash adjustment .....not really hard to do
...but also not hard to get wrong.
Zombient
Junkyard Derelict
Waco, Texas
IMO, it's a Tecumseh. That's the problem.
They're high maintenance engines, the parts are rarely interchangeable, they're not very forgiving, etc. I especially hate the carbs and throttle hookups on them.
Don't get me wrong, they're not "Bad" engines, they're just not as user friendly as Briggs. Or even Predator, for that matter.
I'm curious, how old is this engine? It may not even have OHV.
Zombient
Junkyard Derelict
Waco, Texas
Does it look like this?
NotSoMasterMind
South lyon michigan
If you want to go low budget for cooling, you can get this vent(down below) which will act as a radiator which you can put on the sides or top. This does work knowing since i have done this before
Poboy kartman
Ok....I kinda hate to go here....(since administration doesn't like me picking on newbies) .... but seriously, dude, you just keep spouting off bad worthless advice time after time.....Maybe you should learn a little first, before you spastically hit keys.
