Need help
Prerunner06
I picked up a kart last night and the engine one has no markings or any serial numbers at all. it looks like it was painted and I cant figure out what it is I believe its a 5 hp Briggs and stratton. but i am not certain and don't want to start ordering the wrong parts.
B.M.800
TheBeal.
Central PA
Its a Tecumseh. They went out of business but parts are still available though, just higher pricing.
You may want to look around on your local classifieds for an engine. Im sure you could find a good running engine for about the same price you would spend getting parts for that one.
Is that al you have of that engine?
Prerunner06
no i have the full engine..the kart was running then it sat for a year or so (said the person I picked it up from). I just got into it this morning and tore it apart it looks like its in good condition just needs a cleaning i think i could get it running again...where could I pick up parts? I am looking for exhaust and such or should i just skip the motor and pick up a new one... i picked up the whole cart for 25.00
B.M.800
TheBeal.
Central PA
Oh... well then. Having gotten it for 25 is a deal man! Wish I could get some like that...
What parts do you need? Just the exhaust?
You could probably fab one up, or if you wanted a stock one Im sure you could find one on Ebay.
Give the carb a good cleaning. I wouldnt think it would be too hard to get running.
:thumbsup:
Prerunner06
Yeah for the price I couldn't pass it up I am going to finish cleaning the carb tonight and see what happens it currently has a gravity feed fuel system how can I change that?
You can install a pulse-pump. This is a diaphragm pump, driven by engine vacuum. Exhaust can be as simple as a langth of 3/4" NPT pipe threaded directly into the exhaust port.
If you still have the original sheetmetal, you should be able to locate a model number- possibly stamped directly on to the top.
Prerunner06
I the only sheet metal I have is around the fly wheel didn't see any stamped numbers on it like i said it was painted with a thick engine enamel that covered everything.
B.M.800
TheBeal.
Central PA
I supose it could have been removed at one point. But it sounds like you have all you need to try an get it running?
I'm pretty sure its an L-head Tec. But I agree- more and better pics. I would also like to see an exterior pics of the intake/exhaust ports, and the carb.
Russ- did Clinton have an association with Tecumseh? I must admit that starter cup looks like no Tec I have ever seen.
Russ2251
AZUSA:Powered by LAWN-BOY
No association.
I have Jacobsen 2 cycle engines that have the identical starter up, and also no relationship.
It's possible that they (Jacobsen, Tecumseh, Clinton and others) did use the same ignition systems.
WICO is the name that comes to mind. Magnetos (adjustable timing) are under the flywheel and can be a bear to set-up.
They certainly can. When I swapped out the mag on my H60, I managed to wangle the coil off the laminations, leaving the stator plate in position so I could avoid addressing that situation.
