Need help with torque converter
it will, but why?
the motor is certainly small enough for a series30 TAVkit, which is cheaper and thanks to the 10% overdrive a hair faster in the end.
So unless you do not already have a series 40 .. think about buying a series 30 instead.
Lightfoit8954
Thank you for the reply. The problem I'm having is that the driven pulley is 3/4 bore and I can't find any kits with the right size they're all 5/8 from what I've found. I'm pretty sure it's the tc88 that was on it I can't find the original clutch that came off it.
