Been over a year since I was on here talking about the garden tractor build, which I have yet to start. Anyway, the Sears LT10/E 3 speed with reverse transaxle/transmission that I tore down last year ended up being junk. Few gears were kind of stripped. So after a long time trying to figure out where to go with this, I'm looking at using a Peerless transmission or transaxle. Transaxle will probably be my better bet since those already house the axles and that's 2 less things for me to need to fab up.
I know a few on here have at least in the past used a Peerless 700 series and 800 series, but those threads have been long locked so you can't really do a follow up on it. What tractors does one look at for this transaxle? I'm not at familiar with them but I would not be surprised that the old '72 out of the Sears was one. I know it also depends on application on which direction the input pulley needs to be turning so instead of only having 1 ultra slow forward gear and 3 reverse gears (would be a little fun until you back into a fence or tree )it actually works properly. I'm after the H pattern 3 speed with Reverse since I believe anything more is just a straight shift and not H?
I'm not worried about the input pulley being the type for a vertical shaft engine because after my dad had bought a 2000 2165 Cub Cadet Hydrostatic (dislike hydros, gears or nothing) with a V-twin Briggs and Stratton Vanguard, being as that is a horizontal shaft, right below the pulley off the engine, there's a dual pulley/pulleys that grab the V-belt and in a way convert it to a vertical input without needing to twist the belt (but still runs a long belt). So I can pretty much rip off that design and not need to run a vertical engine.
Thanks in advance!
Thanks in advance!
