Just as I had thought, your driven is installed backwards. With the 40 series, the cam should be inboard (closer to the engine). I know some models (max torque?) can run with the cam outboard, but you need to change the spring around/get a different spring. Blaz should be able to tell you if that is an option with thee 40 series.
