Need Help With my Clutch
prometheusEDI
Washington State
Well guys, I hate for my first post to be a problem but it is what it is.
I just picked up my kart today and while incomplete and to my standards needing much work it does run - but the clutch is for lack of a better term funky. Here's the deal - on pull starting it, it'll engage the clutch at a very low RPM, before the engine spins up to low idle even and stalls the thing. a push start alleviates this problem but at times the clutch seems to bind and kills the motor (somehow, I could be wrong - this is new to me). Either time when watching it, the thing oscillates/vibrates and makes almost the same sound a bad bearing would make on a fan motor or something.
I have no more description to give other than it's a hilliard extreme duty 3/4" shaft clutch. I have not inspected it for it being out of adjustment or damaged - because I have not a clue what Im doing on such a system - I'm used to idler pulleys and belts such as on all terrain lawn tractors :)
Anyway, the thing injured me twice - once when the throttle stuck on a corner as the clutch also stuck (odd combination) the motor stalled and I flipped it over completely back onto it's wheels - and the 2nd, once I got up out of anger to push it back, the thing pop started on it's own and tried taking off - even though the motor was on low idle.
I refuse to ride it at all or let my boy even come near it until I can fix this stuff...
I'd like to refer to Russ' post to try a few drops of oil first,
if that wont help, you should disassemble the clutch and clean it from rust etc.
then try again.
desrtrat
Lynndyl Ut
Mine did something similar, and i agree with sid, take it off, disassemble it, clean and make sure the bearing/bushing in the center is well lubed-greased.
If the lube doesn't do it, nor the cleaning, we might be able to safely assume that the spring(s) are shot.
Don't overdo the oil, just a couple drops. Ensure the chain has a bit of slack in it. If it is "tight", it will compound the problem.
For your own safety, do make sure you have a functioning kill switch within reach before your next shakedown run.
barney, ga.
I will add one thing. if the cleaning and lube takes care of it, and it does have a bronze bushing, order a new one. It seems to me that once they start doing that, the problem returns quickly.
(sintered) Bronze bushings are mostly permalubed, so yes with just a few drops the problem will return fast.
But if you soak the bronze bushing for one or two days they should be as good as new.
