Need help with mounting larger rims
HamptonT
My son and I bought an older Go Kart. It has 6" rims all around. The bolt pattern on the rear hubs is (4) 3-1/8" bolt circle. Seems like an odd size. All I can find is 4 on 4" or 4 on 2-13/16.
Is there an adapter plate out there that I can use to get to the 4 on 4?
Anyone know what make/model???
HamptonT
I think you're right. Carter Brothers
---------- Post added at 05:15 PM ---------- Previous post was at 05:10 PM ----------
It has a 4-3/4" brake drum which I believe is a Carter specific size
anickode
S.E. Michigan
I'm serious, by the way. There's really no reason you couldn't take a generic set of 4 on 4s and add a new set of holes offset by 45° from the existing ones, unless you're looking for authenticity.
