ok on nr racing im going to go with the stage 3 kit that Includes
Race/Open Air Filter & Adapter,
Choice of Bored GX200 , 390 , or 22mm Carb
260 Dyno, CL1, or NR230U Cam
Rev Kit w/18 lb Springs,
8 degree Timing Key,
Small Fan,
Valve Cover Gasket.
Carb gasket
Thin Head Gasket (160 Kits only)
Billet Rod (not shown in picture), Std length on clones, .020 on Hondas.
Case Gasket
optional Header/Exhaust
Guide plate (Clones only)
Rocker arms not included, use stock rockers (1.3 will not work with cams)
(and im going to change up the kit with a 22mm mikuni crab,muffler +clamp,aluminum flywheel,and the 252 0607 packege for the cam) and i shall keep you all update and thanks for all the info and my gov will be removed and r_chez_08 what kindof motor? a honda clone gx200 6.5? and in a couple of mins i will post a pic of the cart i already have ^^
